hi, i am using Keil 4 evaluation version for programming LPC2148. i wrote code for simple led blinking.when i creating new project and creating hex then this hex doesn't work on board. but when i compile same code on previously created project then it work fine. so what are the possible issue and what i have to do....my source code is as follows.....pls give me suggestions....
#include <lpc214x.h> void delay(unsigned int n); void main(void) { PINSEL0 = 0X00000000; IODIR1 = 0xFFFFFFFF; IODIR0 = 0xFFFFFFFF; while(1) { IOSET0 =0xFFFFFFFF; delay(1000); IOCLR0 =0xFFFFFFFF; delay(1000); } } void delay(unsigned int n) { unsigned int i,j; for(i=0;i<n;i++) for(j=0;j<1275;j++); }
you must change the project configuration.
choose "use memory layout from target dialog" from: project\options for target...\linker.
THANK U ITS WORKING...
