Is it possible to use MDK-pro IP networking SLIP with SPI physical interface, which can run faster than UART?
Can it?
Check the datasheet: Most UARTs can go at mega bit/s rates - it's usually just the RS232 transceiver that limits the speed...
(or the desire/need to stick to "standard" baud rates)
UART is limited to 3.7Mbps (with 59MHz clock) or 5.5Mbps at overclocked 88MHz.
