add additional arm compile
Hello everyone,
with Keil 5.14 (mdk_pro) I can select a compiler within the Target options. I'd like to use the compiler Version 4.1.
I installed Keil 5.14 in another folder than Keil 4.13.
then I was looking inside the folder ARMCC from Keil 5.14 and tried to make a similar folder for the old compiler. The folder is named ARMCC_V4_1 and is located in the ARM folder from Keil 5.14. I want to copy the old compiler from Keil 4.13 (if there is another source please tell me).
I copied the BIN40 folder from Keil 4.13 to the ARMCC_V4_1/bin (armar.exe, armcc.exe...)
I copied RV32/INC from Keil4.13 to ARMCC_V4_1/include (headerfiles)
I copied RV32/armlib and RV32/cpplib from Keil 4.13 to ARMCC_V4_1/lib
I cannot find any folder named "sw" in Keil 4.13
What else do I have to copy/create/modify in order to use compiler 4.1 within Keil 5.14?
regards
Alexander
