ST in STMcube prefers FreeRTOS, Keil his RTX. Unfortunately, for example STM32F1 not exist drivers compatible with CMSIS 2.02 and so there is the question of whether to use RTX or FreeRTOS? It is one of them significantly better?
Before that there is, surely, the question of whether to use any OS at all...?
so are you gonna say what you recccomend?
I recommend no OS at all!
why?
without the reason your recccomedation is useless. i can say blue is better than red.
FreeRTOS hands down. Great interface, portability, MPU support, quality code.
thanks. I will look closely at freertos.
nice to see someone give a proper reason.
Proper reason?
"Great interface, portability, MPU support, quality code." is way too short to actually be a proper reason. That sentence doesn't say anything about how great the interface is for the other OS, or what difference there is in portability or MPU support or if there is any difference in code quality. And it doesn't say what actual needs that resulted in that recommendation.
But back to the beginning - you haven't written any information giving the indication that you actually need, or would get any advantages from, using an OS. With zero needs documented by you, people can't give suggestions of what would be a better or worse OS or if you would be just as well off without one. So why complain about lack of reasons from someone else when you didn't start yourself?
Yes, that is true.
But you asked me to give a recommendation without giving any criteria at all upon which to base that recommendation!
In fact, because you have given no criteria - anyone's recommendation here is equally useless!
... could equally apply to the "no OS at all" option!
