Dear All,
I am getting difference in output of Simulator and Emulator on using program Source
#include <reg51.H> void SerTx(unsigned char);
void main(void) {
int counter; TMOD = 0x20; TL1=0xFD; TH1 = 0xFD; SCON = 0x50;
TR1 =1; for(counter=0;counter<10;counter++)
{ SerTx('Y'); SerTx('E'); SerTx('S');
void SerTx(unsigned char x) { SBUF = x; while(!TI); TI=0;
In Simulator , it will show only 10 times 'YES' but in when flashed into a Micro - P89V51RD2, it keep on coming repeatedly.
Please explain
#include <reg51.H> void SerTx(unsigned char); void main(void) { int counter; TMOD = 0x20; TL1=0xFD; TH1 = 0xFD; SCON = 0x50; TR1 =1; for(counter=0;counter<10;counter++) { SerTx('Y'); SerTx('E'); SerTx('S'); } } void SerTx(unsigned char x) { SBUF = x; while(!TI); TI=0; }
for loop has executed 10 times well in Simulator- It will print on 10 time , But if I flash it.. It keep on printing that message where is it going.
Something with Bootloader and main thing , I feel
Your Suggestion of while(1); is correct. I have tried it. But I am trying to figure out the reason why main is getting called again and again when , code is flashed to Controller
Your Suggestion of while(1); is correct. I have tried it. But I am trying to figure out the reason why main is getting called again and again when , code is flashed to Controller because Keil in their infinite wisdom makes a return from main() cause a reset.
NOT UNREASONABLE.
EVEN IF ALL THE POMPOUS GITS WERE BURNT, A POMPOUS GIT WOULD REMAIN.
Dear friend , Can you please explain above. ? POMPOUS GIT ?
