problem with file name returned by ffind
Hi
I am using LPC1768 to store and read data from SD
I have a folder called My1stFolder in which there is a second folder called my2ndFolder
I create some files in M0:\My1stFolder\my2ndFolder and I'd like to read them later
Here is my code:
FINFO CheckFolder (void)
  FINFO F_Info;
  retv=finit (NULL);
  F_Info.fileID = 0;
  while (ffind ("M0:*my2ndFolder*.txt", &F_Info) == 0)
    SendString0("\r\n file name is:");
    SendString0(F_Info.name);
  funinit(NULL);
  retv=1;
  return F_Info;
void SendString0(char * Array)     //send string to UART0 from SRAM
  unsigned int i=0;
  for(i=0;i<strlen(Array);i++)
    sendchar0(Array[i]);
The problem is when I use ffind to search for files in my2ndFolder and try to get the file names, F_Info.name returns the name of the first folder: My1stFolder instead of a complete name (for example M0:\My1stFolder\my2ndFolder\filename.txt) so I cannot get file name to open it
Any help would be extremely appreciated
