Hi I am using LPC1768 to store and read data from SD I have a folder called My1stFolder in which there is a second folder called my2ndFolder I create some files in M0:\My1stFolder\my2ndFolder and I'd like to read them later
Here is my code:
FINFO CheckFolder (void) { FINFO F_Info; retv=finit (NULL); F_Info.fileID = 0; while (ffind ("M0:*my2ndFolder*.txt", &F_Info) == 0) { SendString0("\r\n file name is:"); SendString0(F_Info.name); } funinit(NULL); retv=1; return F_Info; } void SendString0(char * Array) //send string to UART0 from SRAM { unsigned int i=0; for(i=0;i<strlen(Array);i++) sendchar0(Array[i]); }
The problem is when I use ffind to search for files in my2ndFolder and try to get the file names, F_Info.name returns the name of the first folder: My1stFolder instead of a complete name (for example M0:\My1stFolder\my2ndFolder\filename.txt) so I cannot get file name to open it
Any help would be extremely appreciated
Does ffind() support wildcard directory searches? I'm not familiar with the Keil file system code, but most file systems don't work that way. You search the current directory for other files/directories, and then descend/recurse into deeper directories as you find them.
Thanks So how can I step in folders to get file names My folder names have constant names, just the files in second folder may have variable names
