Hi everyone,
I would like to know if something similar happen to you. Well the issue is that when I declare a variable as a global one in the header file of a module with extern sometimes it loses its value. And if I declare it as static I can not access to it from other module. As far As I understand, a static variable is the same during the all of the execution of the program and it has a space of memory reserved to it. Can anyone please clarify this?
Thanks in advance.
I find that conclusion impossible. Nobody ever actually knew what the original problem was, so there's no way to know yours is the same.
