ADC Problem
Hi everyone, I'm getting started with ARM microcontrollers and I'm having a issue with ADC in LPC2148, I'm trying to make work a code that is supposed to read the analog input in AD0.6 (P0.4), and show it on an lcd, Clock and Timer is perfectly setted, the only problem is ADC, it is definetely converting something, but isn't the right results, it oscilate when the tension in the pin is constant and things like that, so I would really appreciate if anyone could help me. Thanks in advance, John.
Here is the code.
#include <lpc214x.h> ///////////////////////
#include "clocks.h"  //    including      //
#include "types.h"   //     libraries     //
#include "lcd.h"     ///////////////////////
#define AD06 ((1<<9)|(1<<8)) //Select AD0.6 function for P0.4
#define SEL_AD06 (1<<6)
#define CLKDIV (15-1) // 4Mhz ADC clock
#define BURST_MODE_OFF (0<<16) // 1 for on and 0 for off
#define PowerUP (1<<21) //ADC on
#define START_NOW ((0<<26)|(0<<25)|(1<<24)) //001 for starting the conversion immediately
#define ADC_DONE (1<<31) //bit done check
#define VREF 3.3 //Reference Voltage at VREF pin
unsigned long AD0CR_setup; //declaration global variable
int result=0; //declaration global variable
int main(void)
        char s[100];
        initClocks(); //Initialize CPU and Peripheral Clocks @ 60Mhz
        initTimer0(); //Initialize Timer0
  lcd_init(); //initialize lcd
        PINSEL0 |= AD06 ; //select AD0.6 for P0.4
        AD0CR_setup = (CLKDIV<<8) | BURST_MODE_OFF | PowerUP;//AD0CR settings
        lcd_puts("\f"); //clear lcd
  while(1)
                AD0CR =  AD0CR_setup | SEL_AD06; //setting up AD0CR register
                AD0CR |= START_NOW; //Start new Conversion
                while( (AD0DR6 & ADC_DONE) == 0 );//wait until conversion is done
                result = (AD0DR6>>6) & 0x3ff;//extracting conversion result of AD0DR6 register
                sprintf(s,"\rV = %.4d",result);//printing result in the lcd
                lcd_puts(s); //printing result in the lcd
                delayMS(1000); //wait 1sec
