SWD connection
Hello everyone!
I'am in a design phase of my first PCB mounter with an ARM processor, and I'am not sure if i correctly connected the programmers pins to the mcu ports.
My processor is:
STM32F302RCT6
I'am planning to program this chip from my F4 discovery board through SWD interface, which can act as an external programmer.
On the PCB I've routed the following pins of the programmer to the chip:
PROGRAMMER PIN | MCU PIN
_______________|_________
T_JTCK | SWCLK-JTCK, PA14
T_JTMS | SWDIO-JTMS, PA13
NRST | NRST
T_SWO | JTDO-TRACESWO
As you can see the chip gets its reset signal from the programmer, but the NJTRST pin is not
connected an it is used as output in the application. Do I make mistake with this configuration?
I'am only planning to use the discovery board as SWD programmer.
Any suggestion am i make any mistakes with this design?
Thank you in advance!
