Hi. I am using a Nordic nRF51422_xxAA (Cortex-M0) and a JLink plus. When I attempt to debug, the message "No Cortex-M Device found in JTAG chain." and "Error: Flash Download failed - Target DLL has been cancelled". There are a couple of problems with the first statement. First, when I use J-Flash software, I am able to connect to the part, so I believe the hardware to be OK. Second, this device uses a SWD connection, not a JTAG. So, I attempt to reconfigure the Flash interface (Flash->Configure Flash Tools, Debug Tab) "Use" is selected, as is "J-LINK / J-TRACE Cortex", then I click on Settings, and "uVision IDE has stopped working ... Windows will close the program..." appears. The only option at that point is a "Close program" button, which closed the IDE.
Please tell me what I am missing. Thank you.
