USBD_Initialize() & USBD_Connect()
Dear All
I use keil µVision V5.10.0.2 and try the blinkey examples of mdk5-getting-started.pdf manual with success on my own HW, but in the USB HID Device example nothing works.
I trace so many point of my HW and SW, and at the last, finding that USBD_Initialize(0) & USBD_Connect(0) functions not working.
Searching for definitions of both to debug, find that they defined as extern in rl_usb.h but there is functions in nowhere (there is other functions which also defined like 2 above as extern with no true functions).
did anyone knows where is the true definition of such functions ? or which header files contain the exact functions to including ?
With Best Regards
Khodadad Namiri
  • Implementations of functions shouldn't be in header files (unless in some situations inlined functions).
    Implementations are expected to be in *.c files.
    And a project need not contain the source code for the functions, in case the project instead links with already compiled object files or libraries containing one or more object files.
