LPC1788 CMSIS SPI driver is missing!
Hello
I'm using Keil 5.10 professional, CMSIS 4.11. I want to use middlewares to connect to a web server, using LPC1788. But when I add ethernet driver to project, I get an error "require 2.01 CMSIS Driver:SPI","Install missing component!".
SPI driver is in the list of API's In the CMSIS-Driver document, but it's not available for me!
I installed the latest version of Packs.
where is the problem? I missed something or that's a software problem and I have to wait for new version?
However, I want to use DP83848, Ethernet PHY driver, not "KSZ8851SNL", but seems Its not possible!!!
I have to write all of the TCP/IP and other things?
  • Hi,
    Yes,since the new version, it lacks many of the target driver for LPC17xx.
    Keil favors new targets. I advise you to stay on the old version 4.xx.
    You will find some examples: "C:\Keil\ARM\Boards\Keil\MCB1700"
    The ethernet driver used is that you seek.
    Good luck.
  • Hi,
    Good luck.
