use of function GRAPH_SCALE_SetFactor of GUI_RTX
I'm facing unexpected behaviour while trying to use function GRAPH_SCALE_SetFactor of GUI_RTX library in my project on Keil MCBSTM32F400 (KeilV4.60 pro).
It is supposed to change the displayed values over the specified axis of a Graph object, according a factor passed in argument as a float, and return the former factor value, in float.
I was wondering why each label was "0" after a call of this function so I wrote this small portion of code to make it clear.
float floatTemp, floatTemp2;
floatTemp2 = 0.2
floatTemp = GRAPH_SCALE_SetFactor(hScaleRfV, floatTemp2);
//after the first call, floatTemp == "1", which seems ok.
//after this second call, floatTemp == 2.802597e-045
It seems the function doesn't return the former value correctly, which I suspect to be big/little endian related, or a double/float interpretation issue. Even the Hex value is different.
I didn't found any example of use in keil directory, the only reference to the function I could find was in segger emwin original sample files, and it seems ok.
Does anybody have any clue on this problem?
Thank you
Regards,
  • In addition, the fact that the value "contained" in the float is beyond the min value of type float (1.175494351e-38F) is really odd...
    I found a way to avoid the float alteration by choosing "Not Used" instead of "Use FPU" for floating point hardware settings in the project options window. But I can't figure out why the STM32F407 goes crazy when it's turned on...
    I'd be glad if someone has an explanation.
    Thank you,
