When the network cable is disconnected and reconnected the LPC1768 does not return to the net, I'm currently using the MDK-Pro version 6.2.
How I can reconnect the LPC1768 in these cases?
http://www.keil.com/forum/58908/
http://www.keil.com/forum/58980/
Thanks Andy on these forums but have not provided a solution to this problem
What function of the MDK-Pro can be used to check the status of the connection and what to reconnect?
You might want to look at http://www.keil.com/forum/18234/
It worked for me.
Thanks Neville but these functions are not in the MDK-Mildware V6.2 of keil 5.
That is correct. You would need to implement the code yourself. To achieve a better product it is often necessary to put in that extra bit of effort.
could you explain a little more how to implement the solution in my project?. Thank you in advance for your help
Maybe, but only if you can highlight something specific that you need clarification on in the details given via the link I gave.
