I am currently doing a project to set up a climate monitoring system by sending data recieved through a temperature sensor on AT89C51ED2(ESA MCB 51-2 development board) to a Xbee module. I have recently started having some problem with the board. Even on trying a simple program like Blinky on the board, when I am debugging and running it using Keil uVision, the program gets stuck and eventually it shows connection to system lost after which I have to reset it but the problem still remains.
I am using the baud rate as 38400 bps and I dont think there is any problem with the COM Ports as the program is getting identified in Keil but then not running.
The code is the following
/* BLINKY.C - LED Flasher for the Keil MCBx51 Evaluation Board with 80C51 device*/ #include <at89c51xd2.h> #include <REG51F.H> void wait (void) { /* wait function */ ; /* only to delay for LED flashes */ } void main (void) { unsigned int i; /* Delay var */ unsigned char j; /* LED var */ while (1) { /* Loop forever */ for (j=0x01; j< 0x40; j<<=1) { /* Blink LED 0, 1, 2, 3, 4, 5, 6, 7 */ P1 = j; /* Output to LED Port */ for (i = 0; i < 50000; i++) { /* Delay for 10000 Counts */ wait (); /* call wait function */ } } for (j=0x40; j> 0x01; j>>=1) { /* Blink LED 7, 6, 5, 4, 3, 2, 1 */ P1 = j; /* Output to LED Port */ for (i = 0; i < 50000; i++) { /* Delay for 10000 Counts */ wait (); /* call wait function */ } } } }
It would be really great if you could help me. Thanks and Regards Pratyush
