With MDK Version 4.72A 3 passes are done with crossmodule optimization enabled:
Build target 'STM32F100V8' Clean started - Project: 'STM32_VL_2xCPU' deleting intermediate output files for target 'STM32F100V8' compiling system_stm32f10x.c... compiling core_cm3.c... ..... ..... compiling stm32f10x_crc.c... linking... Program Size: Code=22928 RO-data=1580 RW-data=144 ZI-data=2440 ".\RVMDK\STM32_VL_DUAL\STM32_VL_DUAL.axf" - 0 Errors, 0 Warning(s).
*** Performing Cross-Module-Optimization: compiling system_stm32f10x.c... ..... ..... compiling stm32f10x_crc.c... linking... Program Size: Code=16268 RO-data=1620 RW-data=144 ZI-data=2440 >>>> unnecessary third round, not seen in MDK Version 4.70 compiling system_stm32f10x.c... compiling core_cm3.c... ..... ..... compiling stm32f10x_crc.c... linking... Program Size: Code=16268 RO-data=1620 RW-data=144 ZI-data=2440
everything is ok, it just seems an extra waste of time.
Cross module optimization (CMO) has changed since 4.70: iterations are performed until no changes in code/const/data sizes occur or a max. of 5 passes have been executed.
From your example, the initial rebuild-step gives:
the first CMO iteration:
the second CMO iteration:
The second CMO iteration does not yield a gain compared to to the first CMO, the iteration process is completed.
You have to pass it to see what's in it, to paraphrase Nancy Pelosi
