I just updated uVision to v4.72.10.0 from v4.71 so that I may build code for TI TM4C123GH6PM. The header file for I/O register definitions, C:\Keil\ARM\INC\TI\TM4C123\TM4C123GH6PM.h, is written in a new format using struct to group all the registers of a module together. Now GPIO_PORTF_DATA_R becomes GPIOF->DATA. Portability and compatibility with TI's TivaWare certainly becomes an issue.
The GPIO Commit Register is defined as __I uint32_t CR; in struct GPIOA_Type and all six GPIO ports are defined with GPIOA_Type. That makes the Commit Register read-only. The commit register bits of GPIOD7 and GPIOF0 and the four JTAG pins of GPIOC should be read/write bit. Or am I missing something?
Use the older header file if that helps.
And complain to Keil if you see any errors in the newer file.
Surely, TivaWare is self-contained - is does not use device headers from the compiler...?
The StellarisWare and the compiler device header files used to be identical prior to v4.72, but not anymore.
I am sure we can write code to work with one header file or the other. My concern is about portability.
See Keil as just a compiler.
Select the header files that best suits your intended use of libraries.
"C:\Keil\ARM\INC\TI\TM4C123\TM4C123GH6PM.h, is written in a new format using struct "
What a nice change - long overdue.
The device specific header files are not meant to be used with TivaWare / StellarisWare: they use inc/hw_xxx and driverlib/xxx header files instead, as stated in the TivaWare manual.
