LPC2377 ISR not firing
I have been trying different sample projects with interrupts, but I can not get the ISR to fire. I have tried BlinkyIRQ both in a board and the simulator, without success.
Is there a global IRQ Enable that needs to be set? I would think the examples would run correctly.
  • With an ARM7 you're going to want to look at the vectors in startup.s/LPC2300.s
    For an LPC23xx I'd presume you'd want it to vector via VicVectAddr, or have a wrapper routine to handle the interrupt context and call routines without the __irq directive.
    You'd need to enable the interrupt in the VIC and peripheral.
    \Keil\ARM\Boards\Keil\MCB2300\Blinky\
