I'm starting a project with STM32F103VB ARM base MCU. How could I Read 96 bit unique ID and manipulate in my software for security and make unique MCU based software.
You don't have _any_ idea at all?
What about just store 96 bits somewhere at a fixed location in the flash? Or use 1-wire interface to a Dallas/Maxim serial-number chip? Or maybe use a SPI serial-number chip?
Why start your project with seeing problems? Why not start by seeing possibilities? A developer is expected to develop, which requires you to be inventive.
printf("STM32F1 %08X-%08X-%08X UNIQUE\r\n", *((unsigned long *)0x1FFFF7E8), *((unsigned long *)0x1FFFF7EC), *((unsigned long *)0x1FFFF7F0) );
dear Per in the project it defined to be secure against of copy although the cpu has protection. best regards
Anyone who gets past the code-protect feature supported by lots of newer processors will not be stopped by some serial number unless you use heavy-duty cryptography. But heavy-duty cryptography requires that you store the crypto key which means that people able to get past code-protect can also extract that crypto key.
Dear per You are right, but if cracking price becomes more than designing new software, I think it's enough to prevent the copy,(not always but often). best regards.
Yes, but then it's normally enough to select a chip with copy-protection, where the chip blocks JTAG and other interfaces from reading out the code from the flash memory.
What actual advantage do you expect to get from your unique serial number, except for the possibility of having the unit send in this serial number to a server for inventory management reasons?
OK Dear Per, I put my hands off, although the project defined so, but I accept your quotes, Best Regards.
It's always best when the requirements specifications focuses on what problems that needs to be solved, instead of hard-coding exactly how the problems should be solved.
That gives the R&D engineers some options to find the best solution instead of having to implement complex or expensive solutions that might not even end up working very well.
Code read-protect makes it harder to duplicate a product. A unique serial number doesn't make it harder to duplicate the product. It only makes it easier to spot that there are duplicated serial numbers on the market - assuming that the devices reports to a common server that can spot the excess registrations. And having large, but sparse, numbers can make the server spot invalid numbers that doesn't follow the secret formula. But it doesn't stop people from creating duplicates that uses the same ID.
But the important thing here is that the CPU doesn't know that it isn't alone to use a specific ID, in case there exists thousands of devices with identical number. It isn't until the devices talks with a server that the duplication can be caught.
So without networking, that serial number is only good for denying warranty if someone sends in a unit with a false ID, or if the service department receives multiple units that uses the same ID. In the field, it takes networking to get any advantage of the serial number. Or that your device is connected to a computer and you mail out a certificate to that computer that is matching the serial number inside the connected device.
