What’s the differences between ip nat inside source and ip nat outside source under the Global mode?
Routers are inspecting incoming and and outgoing packets if they are configured to do so.
The "ip nat inside source" means to inspet an incoming packet originated from an "outside" interface (configured as: ip nat outside) towards an "inside" interface (configured as: ip nat inside) and act accordingly.
The "ip nat outside source" means to inspet an outgoing packet originated from an "inside" interface (configured as: ip nat inside) towards an "outside" interface (configured as: ip nat outside) and act accordingly.
examples from Cisco are numerous!
www.cisco.com/.../13772-12c.gif
www.cisco.com/.../13772-12.html
You can put yourself into the router, the coming data is ip nat inside source while the out date is ip nat outside source. Input the ip nat inside source directly on the internal network side, and input ip nat outside source on the external networks side. The technicist Bill for this answer, the more information about technical support you can send e-mail to bill@huanetwork.com, or visit http://www.huanetwork.com for the big discount of Huawei networking products: Huawei Switch, Huawei Router, Huawei GPON…
