Hi, I am trying just a simple code for DMA test program for MCB1768 ref Board. SRC ADD = 0x2007C000 DST ADD = 0x20080000
In simulation mode it was saying error: *** error 65: access violation at 0x20070000 : no 'write' permission *** error 65: access violation at 0x20080000 : no 'write' permission
I have checked IRAM2 in project option. 0x2007C000 and size 0x8000
then in simulation mode it shows only
*** error 65: access violation at 0x20080000 : no 'write' permission then i have mapped memory
MAP 0x20080000, 0x20081000 READ WRITE
then
It shows *** error 65: access violation at 0x50004008 : no 'write' permission this address belongs to dma control configuration register.
then i mapped MAP 0x50004000, 0x50005000 READ WRITE
then finally i got the error free simulation but i did't get memory data transfered from SRC ADD to DST address.
first time i have faced this issue of "access violation " . Then keil show map all the memory region specified for processor . I should not be set by user to feed manually.
Please do help me . If i am wrong i would love to hear some suggestions.
Regards, Vikas Pandey
Did you consider verifying the simulation support for your processor?
http://www.keil.com/dd/chip/4868.htm
Note that DMA is specifically listed as not supported in the simulation.
