Is data retained if copied from RAM to flash memory using IAP?
I am trying to write a program for an electrical device which needs calibration. The program must calibrate the device and store calibration values. This process is performed in RAM, but I need MCU to retain these information even when the power goes out. Is it the case in IAP? I mean if I copy calibration values from RAM to Flash memory using IAP, will I fulfill my requirement of not loosing them when the micro-controller is turned off?
Thanks in advance for your help
