Wrong sign of enum
I have a simple code like this:
typedef enum
  N1 = 1,
  N2 = 2
} EnumType;
int main(void)
    EnumType A = N1;
    if( A >= 0 )
        return 1;
    return 0;
Comparison with zero gives me warning "#186-D: pointless comparison of unsigned integer with zero".
I then go to project options and check "Enum container always int".
If this code was in *.cpp file - everything is fine, warning goes away (as it should).
But if it's in *.c file - warning is still there!
Compiler key --cpp has the same effect.
This behaviour is very annoying, actually, because I have an entire library filled with such comparisons (and warnings).
Can anyone please tell me, how to remove this very annoying warning and is it a bug or not?
I'm using ARM Keil 4.72.
P.S. I know that I can just disable this warning with a compiler suppressing option (and that's evil by itself) or with pragma but that is not very good solution.
