Hi guys,
I have the following code for a Freescale KL25Z-based Cortex-M0+, which attempts to generate hours, minutes, seconds etc from an epoch time that I'm extracting from the RTC:
#include <MKL25Z4.H> #include <time.h> time_t epochTimeSnapshot; struct tm utcTimeSnapshot; void TimeTakeSnapshot( void ) { epochTimeSnapshot = RTC->TSR; utcTimeSnapshot = *gmtime( &epochTimeSnapshot ); }
I'm compiling this file against C90 and am not using microlib. I've not attempted to customise any of the time.h functions, as I am not using any that are processor independent, just gmtime().
I can confirm that from the RTC, the value 0x51CC6DF8 is being placed into epochTimeSnapshot, which is a correct epoch time from a few days ago as far as I understand it. The issue is that following the execution of gmtime, the utcTimeSnapshot structure is being populated as follows:
tm_sec = 0x1FFFFDA0 tm_min = 0x00000339 tm_hour = 0x00000341 tm_mday = 0x00000343 tm_mon = 0x00000000 tm_year = 0x00000000 tm_wday = 0x00000000 tm_yday = 0x00000000 tm_isdst = 0x00000000
These results are clearly not correct, however I can't determine why this is, as I don't have access to the source of the gmtime function.
Has anyone else experienced any issues like this before? Am I perhaps missing something?
Any advice is much appreciated.
Many thanks
I had the same issue.
basically if I have no GPS timestamp I take the local clock convert to Epoc then add my time offset in seconds and then convert it back to time data
when trying to use the gmtime I would get 0xFFFFFFF (-1) ended up using localtime() and so far it seems to be doing the job
/******************************************************* * Okay have to make a UTC time from the RTC time * and Time Zone ******************************************************/ hw_get_time(&sRTCTime); hw_get_date(&sRTCDate); if(gsSystem.sNVM.wTimeOffset != 0) { time_t lPochSeconds; /************/ sTime.tm_hour = sRTCTime.RTC_Hours; sTime.tm_min = sRTCTime.RTC_Minutes; sTime.tm_sec = sRTCTime.RTC_Seconds; sTime.tm_mday = sRTCDate.RTC_Date; sTime.tm_mon = sRTCDate.RTC_Month; sTime.tm_year = ((sRTCDate.RTC_Year + 2000)-1900); /************************ * Get seconds since Epoc ************************/ lPochSeconds = mktime (&sTime); /* call mktime: timeinfo->tm_wday will be set */ /*********************************** * Add the time Zone adjustment in * 15 minute offsets per count & * convert to seconds (as ublox G100 TMZ command) ************************************/ lPochSeconds -= ((15*60)*gsSystem.sNVM.wTimeOffset); psTime = localtime ( &lPochSeconds ); memcpy(&sTime,psTime,sizeof(struct tm)); gsGSM.sHMI.bGpsHours = sTime.tm_hour; gsGSM.sHMI.bGpsminutes = sTime.tm_min; gsGSM.sHMI.bGpsSeconds = sTime.tm_sec; gsGSM.sHMI.bGpsDate = sTime.tm_mday; gsGSM.sHMI.bGpsMonth = sTime.tm_mon; gsGSM.sHMI.bGpsYear = ((sTime.tm_year+1900)-2000); } else /** no time correction so give RTC time **/ { gsGSM.sHMI.bGpsHours = sRTCTime.RTC_Hours; gsGSM.sHMI.bGpsminutes = sRTCTime.RTC_Minutes; gsGSM.sHMI.bGpsSeconds = sRTCTime.RTC_Seconds; gsGSM.sHMI.bGpsDate = sRTCDate.RTC_Date; gsGSM.sHMI.bGpsMonth = sRTCDate.RTC_Month ; gsGSM.sHMI.bGpsYear = sRTCDate.RTC_Year; } /** Mark we have a GPS time **/ gsGSM.bGpsTimeUpdate = C_GPS_TIME_SET_BY_RTC; }
Although rare, that code is valid, I actually had your example first but modified it to match one I had found whilst trying to resolve the issue, to reduce the number of potential mistakes.
I've further looked into the issue and it appears it may very well be a bug, as substituting the code with the following works perfectly:
#include <MKL25Z4.H> #include <time.h> time_t epochTimeSnapshot; struct tm utcTimeSnapshot; void TimeTakeSnapshot( void ) { epochTimeSnapshot = RTC->TSR; localtime_r( &epochTimeSnapshot, &utcTimeSnapshot ); }
I will have to explore this a little more when I have time and see if I can produce a simple test case.
Code doesn't look right, try
#include <MKL25Z4.H> #include <time.h> time_t epochTimeSnapshot; struct tm * utcTimeSnapshot; void TimeTakeSnapshot( void ) { epochTimeSnapshot = RTC->TSR; utcTimeSnapshot = gmtime( &epochTimeSnapshot ); // look at utcTimeSnapshot->tm_min }
