Filename: RTX_lib.c
static U32 nr_mutex;
int _mutex_initialize (OS_ID *mutex) { /* Allocate and initialize a system mutex. */
if (nr_mutex >= OS_MUTEXCNT) { /* If you are here, you need to increase the number OS_MUTEXCNT. */ for (;;); } *mutex = &std_libmutex[nr_mutex++]; mutex_init (*mutex); return (1); }
Filename: RTX_config.c
// Standard library system mutexes // =============================== // Define max. number system mutexes that are used to protect // the arm standard runtime library. For microlib they are not used. #ifndef OS_MUTEXCNT #define OS_MUTEXCNT 17 #endif
When I run from reset, I'm stuck in for(;;); line above. I hover on nr_mutex and value for nr_mutex is shown in the debugger as 0x80008000. How is this number getting assigned to nr_mutex?
How to resolve this issue?
Thank you!
Look man. You've made a few posts here now. How come you haven't learned to make a post which other people can read without us getting a headache from your mess?
Do it right or don't be surprised if you don't get an answer.
Maybe my post is a little messy because I have no experience with Keil RTX-RTOS. What additional information do you need?
What are you talking about?
Use the <pre> tags!
