Hi, i m working with 89s8253, i have used timer interrupts in my code, i just want to change the start address of my code so that it should not get overlapped with interrupt address. pls help me out Thanks in regards
if C do not worry, it is taken care of if assembler post your coe
It is in C erik, but it does not give me result on hardware. when i removed the interrupt code it yields result on hardware. so not clear whether interrupt address is getting overlaped with mains
