Hello everyone,
I am working with ADC Polling method in LPC1788 and I am using 16*2 LCD for displaying the converted value.
I did all settings as mentioned in user manual and readed the channel 0 as mentioned below.But my LCD is flooding with unmatched values.
my adc settings and reading procedure is as follows,
void adc_init() { LPC_SC->PCONP |= (1<<12); //Power up for ADC
LPC_IOCON->P0_23 &= ~(0x07<<0); //clearing the function of ADC0 pin
LPC_IOCON->P0_23 |= (0x01 & (0x07<<0)); //Selecting func for P0_23 as adc
LPC_GPIO0->DIR |= (0<<23); //Making ADC0[0]-P0.23 as input
LPC_ADC->CR = (1<<0) |(0<<8) | (1<<21); //ADC0[0],so SEL=0x01,clkdiv_ADC=0,PDN=1 }
int adc_read() { unsigned int adc_result,ADC_Data;
LPC_ADC->CR &= ~(0xFF<<0); //clearing the Channel already used ADC0 in SEL bit of CR
LPC_ADC->CR |= (1 << 24) | (1 << channelNum); // switch channel using SEL,start A/D convert */
do { adc_result = LPC_ADC->DR[channelNum]; //Getting channel0's data register value in adc_result variable
/* read result of A/D conversion */
//Note:-Here the ADC_DONE macro value is 0x80000000
}while((adc_result & ADC_DONE)==0); //Waiting for ADC_DONE=1.[i.e DR value to become 0x8]
LPC_ADC->CR &= ~(7<<24); // stop ADC now (i.e.)CR[26:24]=000
ADC_Data = ( adc_result >> 4 ) & 0xFFF; //Getting adc converted result from 4th to 15th bit of DR
return ( ADC_Data );
Reading friends help me to clear the bug and execute as well.
Thanks in advance.
