UDP Response problem
I have a device (K60) with code built using the Keil MDK-Pro and using the TCP_CM3.lib library. I am able receive every UDP packet sent from the PC to the K60. But every other response packet from the K60 is not received by the PC.
This error seems to be rather intermittent. If I build with the No Init options (in Target options) for both IRAM1 and IRAM2 the problem "sometimes" goes away.
Has anyone seen this issue before?
Any ideas?
Thanks,
Mike
