Hello together! I'm having trouble with the USB CDC-Device Class. After sending some thousand of bytes from the Host (PC, Win 7/8) to my devices (NXP LPC1769/1778) the communication fails. For example: After sending a packet of 1002 bytes, the function USBD_CDC_ACM_GetChar() repeats "-1" after reading of 960 bytes. So there seems to be 42 bytes missing. Then, after sending the next packet of 12 bytes, USBD_CDC_ACM_GetChar() does not return the short telegram, but the missing 42 bytes. Exactly after the last byte of the old (large) telegram, the function starts repeating "-1" again. The new (12 byte) telegram is just not recognized. After repeated sending of the 12 byte packet, USBD_CDC_ACM_GetChar() suddenly repeats both (12 byte) telegrams. This is very strange behaviour to me. Seems as if all bytes where received correct inside RL-USB, but the handler is doing something wrong in there.
Any idea what i could do next?
I am using MDK 4.70 and usb_config.c is configured as following: Bulk Endpoint Settings . Bulk In Endpoint Number 2 . Bulk Out Endpoint Number 2 . Endpoint Settings .. Maximum Packet Size 64 Communication Device Settings . Maximum Comm Dev Send Buffer 1024 . Maximum Comm Dev Recv Buffer 1024
Which version of MDK are you using?
MDK 4.70 as mentioned above ;)
Can you first update to latest version of MDK and try?
Recently updated to 4.74 -> no change.. :-(
Can you please specify which microcontroller are you using?
That's also stated in the opening post!
are you using standalone or RTX variant?
My guess is that you are constantly calling USBD_CDC_ACM_GetChar which blocks buffer that receives data and thus does not give the CDC engine time to process the received data, if so can you add a delay between USBD_CDC_ACM_GetChar calls and try then.
Increase Recv Buffer size to 2048, so that "pending" doesn’t work at 1002 bytes.
usb_config.c #define USBD_CDC_ACM_RECEIVEBUF_SIZE 2048
On the wizard, 1024 is the max option. You have to directly touch to this macro with the editor.
> After sending a packet of 1002 bytes, the function USBD_CDC_ACM_GetChar() repeats "-1" after reading of 960 bytes. So there seems to be 42 bytes missing. Then, after sending the next packet of 12 bytes, USBD_CDC_ACM_GetChar() does not return the short telegram, but the missing 42 bytes. Exactly after the last byte of the old (large) telegram, the function starts repeating "-1" again. . Maximum Comm Dev Recv Buffer 1024
Your description suggests that the last packet (42bytes) after 960 (= 64 x 15) bytes on the buffer of 1024 (= 64 x 16) bytes is deferred.
In an old CDC source code of Keil, picked up from MDK v4.22a, I found a bug, which causes the same behavior as you described.
MDK v4.22a \Boards\Keil\MCB2300\USBCDC\cdcuser.c void CDC_BulkOut(void) { int numBytesRead; /* check if we can store the maximum possible received data */ if ((CDC_BUF_SIZE - CDC_BUF_COUNT(CDC_OutBuf)) <= USB_CDC_BUFSIZE) { // <----- (1) CDC_DepOutPending = 1; /* data is pending */ return; } /* get data from USB into intermediate buffer */ numBytesRead = USB_ReadEP(CDC_DEP_OUT, &BulkBufOut[0]); /* store data in a buffer to transmit it over serial interface */ CDC_WrOutBuf ((char *)&BulkBufOut[0], &numBytesRead); }
In this implementation, the line (1) has a bug. This line should be ( "<=" is replaced to "<"), if ((CDC_BUF_SIZE - CDC_BUF_COUNT(CDC_OutBuf)) < USB_CDC_BUFSIZE) {
By this bug, the last packet, which makes the OUT (Receive) buffer full, is unnecessarily deferred (CDC_DepOutPending = 1).
I believe this bug is still living in the current USBD_CDC_ACM implementation.
Tsuneo
