Variable not getting memory allocated
Hello members,
I have following code built successfully with MDK-ARM v4.7.
void FS_update_version_info (void)
{ char *file_src, *file_dest;
strcpy(&file_src[0], folder_path_config);
strcat(file_src, file_path_config);
strcpy(&file_dest[0], folder_path_config);
strcat(file_dest, file_path_config_temp);
When I debug the code, I found that variable "file_dest" is not getting memory allocated, hence it is not getting updated with the assigned value. I tried increasing stack/heap values from startup file. Also tried increasing IRAM1 option from Target->Options dialog but no use. Any idea what is the reason for this? I am using RL-TCP, RL-USB and RL-FlashFS libraries in my code.
Thanks in advance for any help.
Mike.
