Hi everyone
I am facing a weird problem with LPC2148.
I have written a simple code for LPC2148.(Just made some pins high for a particular time) The code works on a development board and a small board which I made.I have powered the micro using only pin 23(VDD) and pin 25(Vss)
But if I remove the lpc2148 and connect pins 23(VDD)and 25(Vss) through jumper cables to the micro controller ,the pins do not turn high.
Should i connect any other pins of the micro controller?Can anyone please inform me the reason why this is happening?
Thanks in advance
I have found out the solution to the problem.....
You are supposed to keep pin 0.14 high. Else it might go into boot mode.
Hope this helps someone....
