I am Modifying the example of CMSIS Driver USART program. when I am debugging the program DMA is not Enable in GPDMA configuration.
LPC_GPDMA->DMACConfig = GPDMA_CONFIG_E; while ((LPC_GPDMA->DMACConfig & GPDMA_CONFIG_E) == 0);
The control is not coming out of while loop. Can anyone help me in this as I am new to ARM Cortex-M3.
#include "Driver_USART.h" void initial_USART0(void); extern ARM_DRIVER_USART Driver_USART0; int main(void) { initial_USART0(); Driver_USART0.Send("ABCDEF",7); while(1); } void initial_USART0(void) { int32_t status=0; status = Driver_USART0.Initialize(NULL); status = Driver_USART0.PowerControl(ARM_POWER_FULL); // configure to UART mode: 8 bits, no parity, 1 stop bit, no flow control, 9600 bps status = Driver_USART0.Control(ARM_USART_MODE_ASYNCHRONOUS | ARM_USART_DATA_BITS_8 | ARM_USART_PARITY_NONE | ARM_USART_STOP_BITS_1 | ARM_USART_FLOW_CONTROL_NONE, 9600); status = Driver_USART0.Control(ARM_USART_MODE_ASYNCHRONOUS, 9600); // enable TX output status = Driver_USART0.Control(ARM_USART_CONTROL_TX, 1); // disable RX output status = Driver_USART0.Control(ARM_USART_CONTROL_RX, 1); }
Regards Arvin
