hi to all, i am creating a something like file explorer with lpc1788,with keil v5.11a as compiler. keil flash file system work correctly and good when i want read any file from memory card,but when i want write to it,some thing happened that surprised(and confused) me!!!! please look at on function of my code(that will copy a file from usb flash disk to memory card) :
unsigned char Copy_File_Flash_To_Sd(char *Dest,char *Source) { FILE* myDest; FRESULT fResult; BYTE res = 0x00; char copyRes = 1; UINT tmp = 1; FIL mySource; //checking that source file exist or no if(f_stat(Source + 4,0x00) != FR_OK) return 0; myDest = fopen(Dest,"w"); //checking for errors when opening file if(myDest == NULL) { char i = 0; //re initlie flash fs(try in three time) for(i = 0;i < 3;i++) { if(finit(0) == 0) break; } //re open file myDest = fopen(Dest,"w"); if(myDest == NULL) return 0; } //opening source file for read(+4 skim "U0:\" part of path) if(f_open(&mySource,Source + 4,FA_READ) != FR_OK) { //closing opened file in sd card fclose(myDest); //reporting that proccess was faild return 0; } //creating a delay msDelay(50); //hitherto all thing is true //reading all byte of source file while(1) { //reading one byte from flash disk fResult = f_read(&mySource,&res,1,&tmp); //check that file_read,read any thing or no if(tmp != 0 || fResult) { /* ..::**** problem is here ****::.. problem is here,that when i want to write res to opened file in sd card only write 4KB of file in it and then fputc return error!!! Surprisingly when change res in below line with '15'(an const int number) it write it correctly(!!!). note that res has valid value,i check it. */ if(fputc(res,myDest) == EOF) { copyRes = 0; break; } } else break; } //closing opened files for(res = 0;res < 3;res++) { if(f_close(&mySource) == FR_OK) break; else if(res == 2) copyRes = 0; } for(res = 0;res < 3;res++) { if(fclose(myDest) == 0) break; if(res == 3) { return 0; } } if(copyRes == 1) return 1; else return 0; }
now any one can help me to fix this problem,any one has any experience with keil flash file system????? Excuse me for long question,i did not know how make it shorter.
regards,alireza sd.
