SPI and SD card
Hi everyone,
I found SD.c that works with SD card thorough SPI for LPC series. But I work with AT91SAM7x256 and I want to change the code to work with this series. I am working on USB and new to memories. This very important to me. I am so grateful for your help.
can anyone help me?
#include"lpc214x.h"
#include "PCF8833.h"
#define SD_Disable() IO0SET |= 1 << 20  //SD Chip Select Pin is P0.7
#define SD_Enable() IO0CLR |= 1 << 20
typedef unsigned char INT8U;
typedef unsigned short INT16U;
typedef unsigned int INT32U;
char CMD[]={0x40, 0x00, 0x00, 0x00, 0x00, 0x95};
INT8U SPI_RW(INT8U data)
        SSPDR = data;
        while((SSPSR & 0x01) == 0);
        return(SSPDR);
void spi_init (void)
   INT32U i;
   /* SSEL is GPIO, output set to high. */
   IODIR0  |= 1<<20;
   IOSET0   = 1<<20;
   /* SCK1, MISO1, MOSI1 are SSP pins. */
   PINSEL1  = (PINSEL1 & ~0x000003FC) | 0x000000A8;
   /* Enable SPI in Master Mode, CPOL=1, CPHA=1 (Clock low-active). */
   SSPCR0 = 0x00C7;
   SSPCR1 = 0x0002;
   SSPCPSR = 0xFE;
   /* Send SPI Command with card not selected at 400 KBit. */
   for (i = 0; i < 16; i++) {
      SPI_RW (0xFF);
   /* Enable SSP auto select. */
  • INT8U Write_Command_SD(INT8U *CMD)
        INT8U i = 0, response = 1, retry = 0;
        SD_Disable();
        SPI_RW(0xff);
        SD_Enable();
        for(i = 0; i < 0x06; i++)
            SPI_RW(*CMD++);
        SPI_RW(0xff);
        do
            response = SPI_RW(0xff);
            retry++;
        while((response== 0xff) && (retry < 100));
        return(response);
        SD_Disable();
        SPI_RW(0xff);
        SD_Enable();
            SPI_RW(*CMD++);
        SPI_RW(0xff);
        do
            retry++;
        return(response);
