I need to make the exchange of information between my development board that is using the LPC1768 and a computer through the "ETHERNET" communication using UDP and SNMP. Since the computer is the CLIENT and the SERVER plate. Can anyone help me somehow? Thank you.
Since you are talking about ETHERNET and communicating between a CLIENT and a SERVER, I get a very strong feeling that you have received a task by your teacher.
So - what have you done, to try to figure out what options you have? Besides asking for forum help?
This is not a task passed by a teacher. Over the past but a task at work. However one has ever done anything with Ethernet if you can help me somehow I thank you.
A packet at a time..
Have you done anything with UDP or TCP/IP? Worked with sockets?
I've never worked with UDP or TCP / IP and socket, I just read about them. however I used the example "EASYWEB" . I did not understand much of this example
What do I need to configure to work with UDP / IP and SOCKET
You'd want a TCP/IP stack, see if you can find a LwIP port for your chip/board.
Heck try doing WinSock on a Windows PC to get your feet wet.
if you have an example I thank you. will help me a lot
