I am successfully able set the time in ds12887 but while reading time it shows wrong time. only second value is coming and overriding hour and minute value. So i cant solve this problem. please take a look in following code.
void DisplayTime() { XBYTE[11]=0x20; hr = XBYTE[14]; writeLcdcmd(0x87); BCD_Conv(hr); WriteLcdData(':'); min = XBYTE[12]; writeLcdcmd(0x8A); BCD_Conv(min); WriteLcdData(':'); sec = XBYTE[00]; writeLcdcmd(0x8D) BCD_Conv(sec); }
but this display only second value and unfortunately hr and min value is also overriding
Next thing: until you can set a time, read it out and display it and see all the fields ticking correctly, you can't just claim that you can correctly set any time.
Try replacing your XDATA[] reads with constants, prove the output routines function properly.
If those work properly, then the values in the XDATA[] array isn't what it's supposed to be and the problem is with how the RTC state is being read into the array (not shown).
Learn how to debug.
