Again, for those who use Keil's middleware - FAT frename function has a nasty bug: if new name contains path (for example "M:\name.txt") the whole string will be used as new name. In this particular case, file will be renamed to M:\name.txt - and now it's not accesible anymore since it contains forbidden characters ':' and '\'. Behaviour is completely wrong. If the path is specified, frename should copy old file to specified destination. In my case, I've created a wrapper function that corrects this issue, which I call instead of frename.
The rename() function does move a file, so the destination name may specify a path to another directory.
But are you sure that the Keil function frename() should move the file, and that it isn't just specified as renaming the file?
The documentation only mentions that the "oldname" string may specify a drive and a path.
http://www.keil.com/support/man/docs/rlarm/rlarm_frename.htm
It is up to you to care about what characters to use.
And you don't seem to have a promise in the documentation that a move to a different directory should be an expected behaviour.
Well, I do not care about move, but specifying invalid file name (containing forbidden characters) should result in returning error code instead of renaming to invalid name, don't you agree?
