fwrite does not result in call to retargetted _sys_write
I have retargetted streamed io as per the following article.
infocenter.arm.com/.../index.jsp
I have added some simple test code as follows:
  FILE * pFile;
  char buffer[] = { 'x' , 'y' , 'z' };
  pFile = fopen ("Results.txt", "wb");
  fwrite (buffer , sizeof(char), sizeof(buffer), pFile);
  fclose (pFile);
When this runs using breakpoints in the debugger I can see that my retargetted _sys_open and _sys_close are called as expected (following the calls to fopen and fclose above), however the call to fwrite does not result in a call to _sys_write and I can not understand why?
int _sys_write(FILEHANDLE fh, const unsigned char * buf,
               unsigned len, int mode)
                return 0;
Any help would be much appreciated.
Thanks,
Andy
