I am learning to use ISD51 on SST89C58. I am using the sample code generic_8052 provided by Keil. The connection is set up correctly and I can STEP through the code. But when I set break points and run, it just hangs for ever! Has anybody tried this tool? Please help! Thanks!
first u must setup ur usrt baud ratio,both in ur target and ur project. second all file is include third u can use isdinit()+isdcheck()to INIT the isdebuger or u can use isdwait() to wait for debuger.
