I've read the posts here, and searched the internet. How does one READ from a slave using a processor with SPI? I can write just fine. I tell my slave that I'm going to write, then I put bits on the bus, and the processor sends out the data with each clock. For reading, I tell my slave that I'm going to read... then when I read the input buffer, it is just equal to my "I'm going to read" instruction fed back to me. How do I tell the processor to start sending clocks for a read so that my slave will start shifting out data?? If I can provide more details, please ask. Any reference to C code that reads from a slave over SPI, or any comments about what my stupid mistake is, would be greatly appreciated. Thanks
Check the datasheet for the device you are using. For example, the Analog Devices ADuC812 states: "SPI is an industry standard synchronous serial interface that allows eight bits of data to be synchronously transmitted and received simultaneously, i.e., full duplex." and "In master mode, the SCLOCK pin is always an output and generates a burst of eight clocks whenever user code writes to the SPIDAT register." So, it sounds like you should receive SPI data from a slave when you first select the slave and then transmit a byte. Jon
Thanks, I've been thinking about that. Since data is sent and received at the same time, I could send "dummy" bits to get the clock going. However, my slave has one pin for input/output and this is switched by another chip. I've been having problems with overwriting data... but now that you mention it, I could write dummy bits to a disabled (disconnected from the slave input/output pin) MOSI line, and read in my data on an enabled MISO line. Hmm, I hope it works... Thanks for the help!
