Hello , please help us to configure the SMTP mail client
SMTP settings that SMTP library accepts and we have configured for 0) Username - maheshmax007@gmail.com 1) Password - ******* 2) From - maheshmax007@gmail.com 3) To - Ramesh@gmail.com 4) Subject - Subject 5) Data - Mail Data
we have confusion between the Username(0) and From(2)to configure.
Thanks in advance
Regards Mahesh M
Try doing it in Thunderbird on a PC, and understand the POP/SMTP setting Google requires there, once that works, uses similar settings here.
We did same Thunderbird settings and applied same in our setting but still not working. Please tell us if there are any more settings to do in keil related to SMTP.
Thanks in advance.
When it fails do you get some specific error code, or anything?
Have you tried other mail servers over which you have control? Perhaps within your own network?
hello,
We have tried doing the SMTP settings as per below:
SMTP server ip = 74.125.136.108
SMTP authentication ID = xyz@gmail.com
SMTP authentication password = password of xyz@gmail.com
MAil server port = 465(SSL)
Source email address = xyz@gmail.com
Recipient email address = xyz@gmail.com
but still we are not able to send mails. So what more we are lacking. Can you please help us out.
Just a question - does the Keil code support SSL-encrypted SMTP connections?
I guess no.
http://www.keil.com/forum/20603/
Can anyone provide setting of working example code of the SMTP (Not the one given in example code)
Thanks in Advance
