Hi!
I'm stucked programming with Keil environment as I didn't find any PWM example code for the EK-TM4C123GXL LaunchPad board.
I found some interesting code for Code Composer Studio (CSS) but I can't use it in Keil, could you give me some tips to do so?
Specifically it's about this Labs at TM4C123G_LaunchPad_Workshop:
processors.wiki.ti.com/.../Getting_Started_with_the_TIVA _C_Series_TM4C123G_LaunchPad
and the labs that are inside:
software-dl.ti.com/.../TM4C123GLaunchPadWorkshopSetup.exe
I'm trying to use the PWM code in Keil but I can't use it.
Even better if you have code to run a PWM module in the EK-TM4C123GXL LaunchPad board.
Thanks!
P.S.: after searching several days in Internet for a solution for PWM module at a EK-TM4C123GXL LaunchPad board I didn't find any solution for Keil, so I think it needs a proper and good solution.
