Hi!
I'm stucked programming with Keil environment as I didn't find any PWM example code for the EK-TM4C123GXL LaunchPad board.
I found some interesting code for Code Composer Studio (CSS) but I can't use it in Keil, could you give me some tips to do so?
Specifically it's about this Labs at TM4C123G_LaunchPad_Workshop:
processors.wiki.ti.com/.../Getting_Started_with_the_TIVA _C_Series_TM4C123G_LaunchPad
and the labs that are inside:
software-dl.ti.com/.../TM4C123GLaunchPadWorkshopSetup.exe
I'm trying to use the PWM code in Keil but I can't use it.
Even better if you have code to run a PWM module in the EK-TM4C123GXL LaunchPad board.
Thanks!
P.S.: after searching several days in Internet for a solution for PWM module at a EK-TM4C123GXL LaunchPad board I didn't find any solution for Keil, so I think it needs a proper and good solution.
hey .. can I get help you. how to use this board. it helps me in my engineering masters academic project.. please send me the relevant data or programs using EK TM4S123GXL
Hi Per,
Thanks for your fast answer!
I coudln't find a right example for the microcontroller TM4C123GH6PM that is in that board for Keil programming environment. I found for CSS but it is useless in Keil.
Ignore the board. Can you find examples for the processor? If so, then it's just a question of what clocking the board has, and what I/O pins that are relevant to use.
