can someone help me with my code
i write code but lcd show x=-1 y=-1 z=-1
can you help me?
<code>
#Include <processer.h>
#use delay (clock = 20000000)
#Use I2C (master, sda = PIN C3, scl = PIN C4)
#define LCD_RS_PIN PIN^b1 ////
#define LCD_RW_PIN PIN.b2 ////
#define LCD_ENABLE_PIN PIN.b3 ////
#define LCD_DATA4 PIN.b4 ////
#define LCD_DATA5 PIN^b5 ////
#define LCD_DATA6 PIN&^b6 ////
#define LCD_DATA7 PIN#b7
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
#include <LCD.c>
int Address = 0xD2; //I2C address of the thing
int x,y,z;
void writeRegister(int deviceAddress, int address,int val) { i2c_start(); i2c_write(deviceAddress); // start transmission to device i2c_write(address); // send register address i2c_write(val); // send value to write i2c_stop(); // end transmission }
void setup(int scale)
{ writeRegister(Address, CTRL_REG3, 0b00001000); if(scale == 250) { writeRegister(Address, CTRL_REG4, 0b00000000); } else if(scale == 500) { writeRegister(Address, CTRL_REG4, 0b00010000); } else { writeRegister(Address, CTRL_REG4, 0b00110000); }
void main()
{ lcd_init();
lcd_gotoxy(1,1);
printf(lcd_putc,"starting up");
delay_ms (1000);
setup(2000); //Configure - 250, 500 or 2000 deg/sec
writeRegister(Address,0x20,0x0F);
delay_ms(1500); //wait for the sensor to be ready
while(true)
{ i2c_start(); i2c_write(Address); i2c_write(0xD3); i2c_start(); int xLSB=i2c_read(0x28); // register to read int xHSB=i2c_read(0x29); // register to read x = make16(xHSB,xLSB); int yLSB=i2c_read(0x2A); int yHSB=i2c_read(0x2B); y = make16(yHSB,yLSB); int zLSB=i2c_read(0x2C); int zHSB=i2c_read(0x2D); z = make16(zHSB,zLSB); i2c_stop(); //This will update x, y, and z with new values lcd_gotoxy(1,2); printf(lcd_putc,"x=%03u",x); lcd_gotoxy(6,1); printf(lcd_putc,"y=%03u",y); lcd_gotoxy(12,1); printf(lcd_putc,"z=%03u",z); delay_ms(100);
<code>
  • Besides totally failing to post your code in the way that was described directly above the message input box, you also failed to say what processor. And you failed to describe what debugging you have done. Or what result you did expect.
    Separate your problem into figuring out if it's the I2C or the LCD code that is wrong - or if the error is somewhere else. But convince us that you have actually tried to figure out this problem yourself and not directly sent it off to this forum for outside consultation.
