Hi
I have been working on LPC2148 for a project. I have tried to get the spi0 working.
Currently the code compiles without a problem but is not responding as it is supposed to. I would like to know if there is any problem with the code in terms of SPI.
#include <lpc214x.h> //Includes LPC2148 register definitions
void spi_init(); void spi_send(char p); char spi_receive();
int main(void) { char p; int i=0; PINSEL0 = (1<<8)|(1<<10)|(1<<12)|(1<<14); // Enable UART1 Rx and Tx pins PINSEL1 = 0x00000000; PINSEL2 = 0x00000000; IO0DIR = (1<<14); IO0CLR |=(1<<14); IO1DIR = (1<<19) | (1<<18) | (1<<17) | (1<<16); spi_init();
while (1) { spi_send('0'); while(p!='0') { p=spi_receive(); }
spi_send('x'); while(p!='x') { p=spi_receive(); }
spi_send('f'); while(p!='f') { p=spi_receive(); }
spi_send('f'); while(p!='f') { p=spi_receive(); } i+=1; p='o'; switch(i%4) { case 1: IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16); IO1SET=(1<<19); break; case 2: IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16); IO1SET=(1<<18); break; case 3: IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16); IO1SET=(1<<17); break; case 0: IO1CLR=(1<<19)|(1<<18)|(1<<17)|(1<<16); IO1SET=(1<<16); break;
} } } void spi_init() { S0SPCR|=(1<<5); S0SPCCR=0x60;
} void spi_send(char p) { int value; value=(int)p; S0SPDR = value; while (!(S0SPSR & 0x80)); } char spi_receive() { char p; while (!(S0SPSR & 0x80)); p=(char)S0SPDR; return p; }
Thanks for the help!!
