code conversion from avr-->arm
hello ,this is the code i made for interfacing an ultrasonic sensor to atmega8 board, it worked fine...
//*atmega8*// #include<avr/io.h> #include<util/delay.h> #include "lcd118010.h"
#define US_PORT PORTC #define US_PIN PINC #define US_DDR DDRC
#define US_TRIG PC5 //PORTA0= trigger #define US_ECHO PC0 // port a1 = echo
This function measusers the width of high pulse in micro second.
#define US_ERROR 0xffff #define US_NO_OBSTACLE 0xfffe // while using macro place the replacing thing "before" the replaced thing with a white space int d; //global variable=distance; uint16_t getPulseWidth() { uint32_t i,result;
//Wait for the rising edge for(i=0;i<600000;i++) { if(!(US_PIN & (1<<US_ECHO))) continue; else break; }
if(i==600000) return 0xffff; //Indicates time out
//High Edge Found
//Setup Timer1 TCCR1A=0X00; TCCR1B=(1<<CS11); //Prescaler = Fcpu/8 TCNT1=0x00; //Init counter
//Now wait for the falling edge for(i=0;i<600000;i++) { if(US_PIN & (1<<US_ECHO)) { if(TCNT1 > 60000) break; else continue; } else break; }
//Falling edge found
result=TCNT1;
//Stop Timer TCCR1B=0x00;
if(result > 60000) return 0xfffe; //No obstacle else return (result>>1); }
void move_robo() { if(d<20) { PORTD=0x10; _delay_ms(100); } else if(d>20) { PORTD=0xa0; _delay_ms(100); } else { PORTD=0x90; /// spin }
void Wait() { uint8_t i; for(i=0;i<10;i++) _delay_loop_2(0); } int main() { DDRD=0xf0; PORTD=0x00; uint16_t r;
Wait();
//Initialize the LCD Module lcd_init();
Wait();
lcd_clear(); lcd_gotoxy(0,0); lcd_string("HC SR04 TEST");
Wait(); Wait(); Wait(); Wait(); Wait(); Wait();
lcd_clear();
while(1) {
//Set Ultra Sonic Port as out US_DDR|=(1<<US_TRIG);
_delay_us(10);
//Give the US pin a 15us High Pulse US_PORT|=(1<<US_TRIG); //High
_delay_us(15);
US_PORT&=(~(1<<US_TRIG));//Low
_delay_us(20); //Now make the pin input US_DDR&=(~(1<<US_ECHO)); //Measure the width of pulse r=getPulseWidth();
//Handle Errors if(r==US_ERROR) { lcd_clear(); lcd_gotoxy(0,0); _delay_us(100); lcd_string("error"); } else if(r==US_NO_OBSTACLE) { lcd_gotoxy(0,0);
\ _delay_us(100); lcd_string("clear"); } else {
d=(r/58.0); //Convert to cm lcd_gotoxy(1,0); lcd_string("d="); _delay_us(100); lcd_gotoxy(1,4); lcd_showvalue(d); _delay_ms(50); lcd_gotoxy(1,7); lcd_string("cm"); _delay_ms(100); if(d>20) { PORTD=0xa0; _delay_ms(200); } else { move_robo(); }
Wait(); } } }
BUT,WHEN I CONVERTED THIS CODE INTO ARM
microcontroller: LPC1768-Cortex M3
clock: 12mhz
compiler Keil uVision 4
#include "LPC17xx.h"
#include "delay.h"
#include "type.h"
#include "lcd.h"
#define US_PORTCLR LPC_GPIO0->FIOCLR
#define US_PORTSET LPC_GPIO0->FIOSET
#define US_DDR LPC_GPIO0->FIODIR
#define US_PIN LPC_GPIO0->FIOPIN
#define US_ECHO 5 // pot 0 5th pin for echo
#define US_TRIG 6 // p0.6 for trigger #define US_ERROR 0xffff #define US_NO_OBSTACLE 0xfffe
uint32_t d;
//High Edge Found
//Setup Timer1 LPC_SC->PCONP |= 1 << 1; //Power up Timer 0 LPC_SC->PCLKSEL0 |= 1 << 2; // Clock for timer = CCLK
LPC_TIM0->TCR |= 1 << 1; LPC_TIM0->TCR |= 1 << 0; // Start timer
//Now wait for the falling edge for(i=0;i<600000;i++) { if(US_PIN & (1<<US_ECHO)) { if((LPC_TIM0->TC) > 60000) break; else continue; } else break; }
result=(LPC_TIM0->TC); //STORE COUNT IN RESULT
//Stop Timer LPC_TIM0->TCR |= 0 << 0;
int main (void)
{ uint16_t r; SystemInit(); lcd_init(); delay_ms(50);
delay_ms(50);
while(1) { //Set Ultra Sonic Port as out US_DDR|=(1<<US_TRIG);
delay_us(10);
//Give the US pin a 15us High Pulse US_PORTSET|=(1<<US_TRIG); //High
delay_us(15);
US_PORTCLR|=(1<<US_TRIG);//Low
//Handle Errors if(r==US_ERROR) { lcd_clear(); lcd_gotoxy(0,0); delay_us(100); lcd_string("error"); } else if(r==US_NO_OBSTACLE) { lcd_gotoxy(0,0);
\ delay_us(100); lcd_string("clear"); } else {
d=(r/58.0); //Convert to cm lcd_gotoxy(1,0); lcd_string("d="); delay_us(100); lcd_gotoxy(1,4); lcd_showvalue(d); delay_ms(50); lcd_gotoxy(1,7); lcd_string("cm"); delay_ms(100);
IT IS NOT DOING, LCD IS DISPLAYING USELESS VALUES..
PLEASE HELP ME CORRECTING THE CODE FOR ARM..
ULTRASONIC MODULE I USED IS HC SR04
i thing i may have missed some timer concepts; as i'm a beginner
THANKYOU
  • Didn't you kind of forget to read the instructions how to post your source code to make it readable? Note the information text directly above the Message input box.
    Posting your code indented and with line breaks at reasonable places will greatly increase your chance of having people actually looking at the code.
