Find end of code
I'm using LPC23xx family and I create option in my code to send the existing code thrue the rs485 to all other unit that are connected.
I add extra memory to each unit and one (main) unit (after it updated manually -with ulink) and then it send the new firmware to all other unit. after the units gets the new firmware it automatically update using IAP the exist firmware.
Everything works...
I Want that the main unit send only the 'code' part of itself so it must found the end of the code.
When I look at the MAP file I notice that at the end of the code there is 'Region$$Table anon$$obj.o' So if I could use this location as a parameter in my code I will know how long it is.
Maybe there is other way to know the size of my code?
I don't want to check every time the size and add it manually (as I do it now) ,I want it to be automatically..
Any solution?
  • Yes - the way to do it is to have a symbol of known name linked last. Then you know exactly how much you need to copy. You may either play with one of the Keil-supplied symbols - in this case Region$$Table$$Limit - and use that to initialize a variable. Or add your own symbol that you specify to be placed last by modifying the scatter file.
