Questions about NXP LPC Series' USB
(Sorry for my limited English and technical skills.)
Based on my experience, I think USB device controllers in LPC2148, LPC2368, and LPC1768 are very similar, or even the same.
However, the USB device controller in LPC1343 is a little different from LPC2148.
It does not have Endpoint interrupt registers and Endpoint realization registers.
More surprising to me, LPC1347 and LPC11Uxx have the same USB device controller, but this USB controller is very different from LPC1343 one.
Some of the LPC13xx, LPC11Uxx have internal USB ROM driver, but some NXP USB Source Code tell me that, some of the USB ROM drivers have bug.
And more surprising to me, NXP decided to use LUFA (Lightweight USB Framework for AVRs, formerly known as MyUSB) as their USB Stack. Some Internet web-pages tell me that, some of the NXP USB example code does NOT work properly.
NXP now provides: Sample Code Bundle, CMSIS driver library, nxpUSBlib software package, LPCOpen Software Development Platform; + LPCXpresso, and ARM's mbed. So many choices confuse me badly.
I have some USBCDC experience based on bertrik's LPCUSB Stack, so I guess I would be able to port USBCDC example of LPCUSB from LPC2368/LPC1768 to LPC1343.
However, I am not so sure about the better/best approach for NXP LPC Series' USB solution; assumed that, what I need is only USBCDC functionality, and my target MCU are LPC1788, LPC1768, LPC1343, and LPC11U14.
1. Is it very difficult to port USBCDC example of LPCUSB from LPC2368/LPC1768 to LPC1343?
2. Is NXP's internal USB ROM driver with their USB Stack ready for production?
3. If I want to design a low cost, low pin count, Cortex-Mx based device, with USBCDC functionality, is there any best approach available? NXP MCU or ST MCU or others? It seems TI's Tiva is always under Preview.
  • > 1. Is it very difficult to port USBCDC example of LPCUSB from LPC2368/LPC1768 to LPC1343?
    Not so much.
    The USB device engine of LPC1343 is a simplified version of traditional LPC USB SIE on LPC2368/LPC1768 (and LPC 2148).
    - LPC1343 doesn’t have USB DMA capability.
    - DMA-related registers (including DMA interrupts) have been gone away.
    - The device and endpoint interrupts are unified into USBDevInt-St/En/Clr/Set registers.
    And then, replacing registers on LPCUSB, you’ll port it into LPC1343, without changing outline of the code flow.
    The USB on-chip driver on LPC1343 is an early version of ROM driver.
    - It implements just HID and MSC (Mass-Storage Class).
    - Customization of driver functionality is not considered at all.
    If you would be fully satisfied on its function, you are lucky ;-)
    I recommend you LPC11Uxx.
    Tsuneo
    Not so much.
    Tsuneo
