Placing suffix u with unsigned variables
I was reading on misra website that for assigning 0 to unsigned variable, 'u' must be suffixed.
For example:
uint8_t my_cnt = 0U;
1. Does that even on declaring array I should use this.Like
uint8_t my_arr[10U];
2. Also while using switch cases like:
void func(uint8_t no)
    switch(no)
         case 1U:
         break;
         case 2U:
         break;
If yes then what if variable passed to switch is of int8_t type. In above example if
int8_t no;
